EASY, INTUITIVE, AND CONSISTENT
imageRUNNER ADVANCE devices are designed to be in sync with how users work. All models feature a large 10.1” responsive and intuitive touch screen, making operation clear and seamless. User-friendly techniques echo the operation of smartphones and tablets.
No matter which imageRUNNER ADVANCE model the user is operating, the interface remains the same, allowing work to proceed effortlessly and with a minimal learning curve.
A CUSTOMIZED EXPERIENCE
Users can customize their experience to their personal preferences. Once they log in, they’ll see their preferred default login screen and desired language; preferred settings for Copy, Send, Fax, and Store; accessibility settings; and more—all following them from device to device. Users can also take advantage of single sign on (SSO) to access and scan to available cloud services destinations.
With HotFolders, users can drag and drop files (PDF, JPG, or TIFF) to local shared folders on the user’s PC. Files are printed with the print settings set beforehand by the administrator for each specific folder. No driver is needed for this setup. This is a perfect solution for utilizing repetitive tasks, workflows, and help administrator management of drivers.
INTEGRATING WORKFLOWS AND ACCESS TO THE CLOUD
Addressing the trending increase in the use of cloud-based services, the imageRUNNER ADVANCE models are cloud-ready, engaging with many popular cloud services. And, these models integrate seamlessly with Canon software as well as many third-party solutions and enterprise applications, so organizations can benefit from powerful output management, document capture, information management, and other productivity-boosting solutions.
HIGH QUALITY AND DURABILITY FOR HASSLE-FREE UPTIME
imageRUNNER ADVANCE systems have a well-earned reputation as workhorses, helping to keep office productivity high and minimizing the impact on support resources.
In fact, the imageRUNNER ADVANCE platform has received many awards and recognition from leading industry analysts, often referencing strong reliability.
CENTRALLY MANAGE A FLEET
Canon imageRUNNER ADVANCE models support centralized device management, allowing for the control of an entire fleet from one central point. It’s easy and intuitive to monitor device status and consumables, turn off devices remotely, observe meter readings, manage address books and print drivers, implement security policies, even update firmware and device settings - anytime, anywhere.
EASY TO SET UP, EASY TO MAINTAIN
Devices can be configured for quick, easy deployment. Remote diagnostics and parts life management enable proactive maintenance and rapid fixes for maximum uptime.
Intelligent, service-friendly engineering helps ensure easy access to, and replacement of, parts while upgrades are easy to apply when needed.
© 2020 Canon U.S.A., Inc. All Rights Reserved. Reproduction in whole or in part without permission is prohibited.
