EOS R |
Image Sensor | 30.3 MP Full-frame CMOS (36.0 x 24.0mm) |
Image Processor | DIGIC 8 |
Lens Mount | Canon RF mount |
Compatible Lenses | RF lenses (Compatible with EF & EF-S lenses when using optional Mount Adapter EF-EOS R) |
Autofocus | Focus Control |
Phase-difference detection system with image sensor (Dual Pixel CMOS AF) |
AF Area |
Approx. 88% horizontal by 100% vertical
(Area size varies according to compatible lens) |
Available AF Areas |
Maximum 143 area
AF Points |
Maximum of 5,655 manually selectable* (When selected with cross keys)
AF Working Range |
EV -6 to 18 (f/1.2, at 73°F/23°C, ISO 100, One-Shot AF)
AF Method |
Face+Tracking AF, 1-point AF **, Expand AF area (Above, below, left and right),
Expand AF area (Around), Zone AF, Large Zone AF (Vertical), Large Zone AF (Horizontal) |
Maximum Frames Per Second |
High-speed continuous shooting: Approx. 8.0 fps, With Servo AF: Approx. 5.0 fps (shooting speed priority) |
Still Image Capture | Image Format |
JPEG, RAW (14 bit Canon original), C-RAW (Canon original)
File Size |
3:2 Aspect Ratio: Large/RAW/C-RAW: 6720 x 4480,
Medium: 4464 x 2976, Small 1: 3360 x 2240, Small 2: 2400 x 1600 1.6x (Crop): Large/RAW/C-RAW: 4176 x 2784, Small 2: 2400 x 1600 4:3 Aspect Ratio: Large/RAW/C-RAW: 5952 x 4480***, Medium: 3968 x 2976, Small 1: 2976 x 2240***, Small 2: 2112 x 1600*** 16:9 Aspect Ratio***: Large/RAW/C-RAW: 6720 x 3776, Medium: 4464 x 2512, Small 1: 3360 x 1888, Small 2: 2400 x 1344 1:1 Aspect Ratio: Large/RAW/C-RAW: 4480 x 4480, Medium: 2976 x 2976, Small 1: 2240 x 2240, Small 2: 1600 x 1600 |
Video Recording | File Format |
MP4
Video Encode |
MPEG-4 AVC/H.264 compression
Audio Format |
ALL-I uses Linear PCM, IPB uses AAC through built-in stereo microphone or optional external microphone
Video Recording |
4K 3840 x 2160: 29.97 fps/24.00 fps/23.98 fps, ALL-I: 480 Mbps, 3444 MB/min.
4K 3840 x 2160: 29.97 fps/24.00 fps/23.98 fps, IPB: 120 Mbps, 860 MB/min. Full HD 1920 x 1080: 59.94 fps^, ALL-I: 180 Mbps, 1298 MB/min. Full HD 1920 x 1080: 59.94 fps^, IPB: 60 Mbps, 431 MB/min. Full HD 1920 x 1080: 29.97 fps/24.00 fps/23.98 fps/HDR Video, ALL-I: 90 Mbps, 654 MB/min. Full HD 1920 x 1080: 29.97 fps/24.00 fps/23.98 fps/HDR Video, IPB: 30 Mbps, 216 MB/min. Full HD 1920 x 1080: 29.97 fps, IPB Light: 12 Mbps, 87 MB/min. HD 1280 x 720: 119.9 fps, ALL-I: 160 Mbps, 1144 MB/min. HD 1280 x 720: 59.94 fps, ALL-I: 80 Mbps, 583 MB/min. HD 1280 x 720: 59.94 fps, IPB: 26 Mbps, 187 MB/min. HD 1280 x 720: 29.97 fps/HDR Video, IPB: 13 Mbps, 94 MB/min. |
Canon Log | Dynamic Range |
Approx. 800%
Canon Log Recording |
4K/Full HD/HD YCbCr 4:2:0 BT.709 8-bit (Internal Memory)
4K/Full HD/HD YCbCr 4:2:2 BT.709 8-bit (HDMI Output) 4K YCbCr 4:2:2 BT.709/BT.2020 10-bit (HDMI Output) |
Exposure Control | Metering Modes |
Real-time metering
Metering Range |
EV -3 to 20 (at 73°F/23°C, ISO 100)
Shooting Modes |
Scene Intelligent Auto, Flexible-priority AE, Program AE, Shutter-priority AE, Aperture-priority AE, Manual Exposure, Bulb Exposure, Custom Shooting Modes: C1, C2, C3
ISO Speed |
ISO 100 to 40000 (in 1/3-stop or whole-stop increments)
ISO Expansion |
L: 50, H1: 51200, H2: 102400
Exposure Compensation |
±3-stops in 1/3- or 1/2-stop increments
AE Lock |
Auto, Manual
Recording Media | SD/SDHC/SDXC Memory Cards |
Shutter | Type |
Electronically controlled focal-plane shutter
Shutter Speed |
1/8000–30 sec., bulb.
Maximum Sync. Speed |
X-sync at 1/200 sec.
Viewfinder | Type |
OLED Electronic Viewfinder
Screen Size |
0.5-inch diagonal
Magnification |
Approx. 0.76x (with 50mm lens at infinity, -1 m-1))
Resolution |
Approx. 3.69 million dots
Information |
AF point information, Number of remaining multiple exposures, HDR shooting, Multiple-exposure shooting, Dual Pixel RAW shooting, Multi Shot Noise Reduction, Digital Lens Optimizer, AF method, AF operation, Drive mode, Metering mode, Anti-flicker shooting, Shooting mode, Scene icons, AE lock, Flash-ready, Flash off, FE lock, High-speed sync, Shutter speed, Multi-function lock warning, Aperture, Lens information, Exposure level indicator, Exposure compensation, Highlight tone priority, ISO speed, Possible shots, Number of self-timer shooting, Maximum burst, Battery level, Exposure simulation, AEB, FEB, Still photo cropping, Aspect ratio, Auto Lighting Optimizer, Picture Style, White balance, White balance correction, Image Quality, Bluetooth® function, Wi-Fi® function, Histogram, Electronic level
LCD Monitor | Type |
TFT Color Clear View II LCD Touchscreen
Screen Size |
3.15-inch diagonal
Resolution |
Approx. 2.10 million dots
Coverage |
Approx. 100% vertically/horizontally
Wi-Fi ® Connectivity |
IEEE 802.11b/g/n Compatible
Bluetooth® Connectivity |
Bluetooth® Version 4.1 compliant
Exterior | Dimension (W x H x D) |
Approx. 5.35 x 3.87 x 3.32 in. / 135.8 x 98.3 x 84.4mm • Based on CIPA standards Approx. 5.35 x 3.87 x 2.67 in. / 135.8 x 98.3 x 67.7mm (from grip to monitor) |
Weight (CIPA) |
Approx. 1.46 lbs. / 660g
* Available AF points may decrease when shooting with AF cropping or in movie mode, or depending on camera settings or lens attached.
** [AF frame size] can be set to [Small].
*** Indicate an inexact proportion.
^ Full HD 59.94 fps not available during EF-S cropped shooting.
RF 28–70mm
F2 L USM |
RF 50mm
F1.2 L USM |
RF 24–105mm
F4 L IS USM |
RF 35mm F1.8
Macro IS STM |
RF 28–70mm |
RF 50mm |
RF 24–105mm |
RF 35mm F1.8 |
Lens Type |
Canon RF Lens
Canon RF Lens
Canon RF Lens
Canon RF Lens
Focal Length & Maximum Aperture | 28-70mm, f/2 |
50mm, f/1.2 |
24-105mm, f/4 |
35mm, f/1.8 |
Lens Construction | 19 elements in 13 groups |
15 elements in 9 groups |
18 elements in 14 groups |
11 elements in 9 groups |
Diagonal Angle of View | 75°00' - 34°00' |
46°00' |
84°00' - 23°20' |
63°00' |
Focusing Actuator | Ring USM |
Ring USM |
NANO USM |
Gear-type STM |
Minimum Focusing Distance | 1.28 ft. / 0.39m |
1.31 ft. /0.4m |
1.48 ft. / 0.45m |
0.56 ft. / 0.17m |
Image Stabilization | N/A |
N/A |
Provided (Up to 5 stops with compatible camera) |
Aperture Blades | 9 blades |
10 blades |
9 blades |
9 blades |
Filter Size | 95mm |
77mm |
77mm |
52mm |
Maximum Diameter & Length | Ø4.09 x 5.50 in. / Ø103.8 x 139.8mm |
Ø3.54 x 4.25 in. / Ø89.8 x 108.0mm |
Ø3.29 x 4.22 in. / Ø83.5 x 107.3mm, |
Ø2.93 x 2.47 in. / Ø74.4 x 62.8mm |
Weight | Approx. 3.15 lbs. / 1430g |
Approx. 2.09 lbs. / 950g |
Approx. 1.54 lbs. / 700g |
Approx. 0.68 lbs. / 305g |
