NEW RF MOUNT
At the heart of the EOS R system lies the amazing RF mount. It’s newly designed to deliver the ideal combination of speed, durability and flexibility in optical design for excellent performance and future system expansion, plus compatibility with EF and EF-S lenses*.
54 mm
DIAMETER
SHORT
BACK FOCUS
OPTICAL EXCELLENCE
54mm Large Diameter and Short Back Focus
The large diameter and decreased distance between the rear lens element and sensor enable a compelling combination of image quality, performance and compact lens design. The new RF mount retains the same, large 54mm diameter as the current Canon EF mount, but thanks to the EOS R camera’s mirrorless structure, the rear lens element can be much closer to the image plane. This combination opens up a number of possibilities. The rear element of RF lenses can be larger in diameter, improving image quality at the corners and outer edges of the frame. Larger rear elements mean front elements can be smaller, meaning less strong refracting and bending of light rays within the lens, enhancing optical performance. Most importantly, the EOS R system opens the door to the future. It unlocks more freedom and flexibility in lens designs, allowing faster lenses with increased optical performance in more compact forms than before.
© Lindsay Adler,
Canon Europe Ambassador
20mm Flange Focal Distance
The RF mount is mounted just 20mm from the image sensor. This provides flexibility for future lens designs and the durability needed for professional, real-world operation, even when using super telephoto lenses.
HIGH-CAPACITY & HIGH-SPEED DATA TRANSMISSION
Data Transmission through 12 pin Electrodes
A 12 pin connection between the camera and lens means communication at a higher speed with larger amounts of data transfer, enabling incredibly fast AF, high IS and image optimization. It’s a system designed to expedite operations that’s ready for future expansions.
12 PIN CONNECTION
COMPATIBILITY WITH EF/EF-S LENSES
Mount adapters deliver seamless connections between the EOS R camera and EF and EF-S lenses with all functions intact. Offering L series level weather and dust sealing, they are even compatible with EF extenders like the Extender EF 1.4x III to extend your camera’s optical reach. With an entire arsenal of EF and EF-S lenses at your disposal, these mount adapters ensure endless creative possibilities for the EOS R camera.
BEYOND FULL COMPATIBILITY WITH EF/EF-S LENSES
Take full advantage of the EOS system by using any EF/EF-S lens with the EOS R camera by way of three optional mount adapters, including one featuring a customizable control ring and another allowing you to drop in a circular polarizing or variable ND filter.
CONTROL RING
MOUNT ADAPTER
EF-EOS R
EOS R
Control Ring
Mount Adapter EF-EOS R
EF 100–400mm f/4.5-5.6L IS II USM
EOS R
Drop-in Filter
EF 11–24mm f/4L USM
DROP-IN FILTER
MOUNT ADAPTER
EF-EOS R
MOUNT
ADAPTERS EF-EOS R
MOUNT ADAPTER EF-EOS R
Lightweight and compact, the Mount Adapter EF-EOS R connects EF and EF-S lenses to the EOS R, exponentially expanding the list of compatible lenses.
CONTROL RING MOUNT ADAPTER EF-EOS R
The Control Ring Mount Adapter EF-EOS R adds a control ring like those found on RF lenses, providing the same level of control to your EF and EF-S lenses and supporting the same setting configuration regardless of lens.
DROP-IN FILTER MOUNT ADAPTER EF-EOS R
The Drop-in Filter Mount Adapter EF-EOS R enables compatibility with EF and EF-S lenses and includes drop-in filter capability for use with circular polarizing filters or variable ND filters. This enhancement enables compatibility with numerous lenses regardless of their front diameter, and makes filter use possible with lenses like the ultra wide EF 11–24mm f/4L USM lens or the tilt-shift TS-E 17mm f/4L lens which cannot accept a filter on the front.
© Jimmy Chin, Canon Explorer of Light
EOS FULL-FRAME
The EOS R camera camera helps expand the impressive lineup of Canon full-frame cameras such as the EOS-1D X Mark II, EOS 5DS, EOS 5DS R, EOS 5D Mark IV and EOS 6D Mark II to provide a wealth of amazing and powerful full-frame options. Using lenses at their original focal length, the EOS R benefits from a range of improvements made possible by the large physical size of full-frame sensors.
EOS FULL-FRAME POWER
INCREDIBLE IMAGE
QUALITY
High-capacity Information
Not only can Canon’s full-frame sensors capture a tremendous amount of information at a full 24 x 36mm, but they can also capture large individual pixels for great quality of detail and low noise.
EOS R with RF 28–70mm F2 L USM
IMPRESSIVE
PERFORMANCE IN
LOW LIGHT
High Range of Sensitivities
Full-frame sensors excel in low light, as their physical size helps ensure high light sensitivity. This means superb, clean and detailed images at high ISOs, plus impressive handheld performance in a variety of situations.
BEAUTIFUL BOKEH
Shallow Depth of Field
Full-frame sensors offer shallow depth of field by design, making it easy to define depth of focus through aperture choice. These sensors deliver gorgeous and soft out of focus areas when shooting with large apertures.
EOS R with RF 50mm F1.2 L USM
WIDE ANGLE OF VIEW
Effective Focal Length
Thanks to full-frame, cameras like the EOS R can take advantage of RF, EF* and EF-S* lenses at their original focal length for impressive wide-angle performance and rendition across the image plane.
EOS R with RF 24–105mm F4 L IS USM
* Optional Mount Adapter EF-EOS R is required when using EF/EF-S lenses with an EOS R camera.
