SPECIFICATIONS
EOS R
EOS R
EOS R
EOS R
Image Sensor
30.3 MP Full-frame CMOS (36.0 x 24.0mm)
Image Processor
DIGIC 8
Lens Mount
Canon RF mount
Compatible Lenses
RF lenses (Compatible with EF & EF-S lenses when using optional Mount Adapter EF-EOS R)
Autofocus Focus Control
Phase-difference detection system with image sensor
(Dual Pixel CMOS AF)
AF Area
Approx. 88% horizontal by 100% vertical
(Area size varies according to compatible lens)
Available AF Areas
Maximum 143 area
AF Points
Maximum of 5,655 manually selectable* (When selected with cross keys)
AF Working Range
EV -6 to 18 (f/1.2, at 73°F/23°C, ISO 100, One-Shot AF)
AF Method
Face+Tracking AF, 1-point AF **, Expand AF area (Above, below, left and right),
Expand AF area (Around), Zone AF, Large Zone AF (Vertical),
Large Zone AF (Horizontal)
Maximum Frames Per Second
High-speed continuous shooting: Approx. 8.0 fps,
With Servo AF: Approx. 5.0 fps (shooting speed priority)
Still Image Capture Image Format
JPEG, RAW (14 bit Canon original), C-RAW (Canon original)
File Size
3:2 Aspect Ratio: Large/RAW/C-RAW: 6720 x 4480,
Medium: 4464 x 2976, Small 1: 3360 x 2240, Small 2: 2400 x 1600
1.6x (Crop): Large/RAW/C-RAW: 4176 x 2784, Small 2: 2400 x 1600
4:3 Aspect Ratio: Large/RAW/C-RAW: 5952 x 4480***,
Medium: 3968 x 2976, Small 1: 2976 x 2240***, Small 2: 2112 x 1600***
16:9 Aspect Ratio***: Large/RAW/C-RAW: 6720 x 3776,
Medium: 4464 x 2512, Small 1: 3360 x 1888, Small 2: 2400 x 1344
1:1 Aspect Ratio: Large/RAW/C-RAW: 4480 x 4480,
Medium: 2976 x 2976, Small 1: 2240 x 2240, Small 2: 1600 x 1600
Video Recording File Format
MP4
Video Encode
MPEG-4 AVC/H.264 compression
Audio Format
ALL-I uses Linear PCM, IPB uses AAC through built-in stereo microphone or optional external microphone
Video Recording
4K 3840 x 2160: 29.97 fps/24.00 fps/23.98 fps, ALL-I: 480 Mbps, 3444 MB/min.
4K 3840 x 2160: 29.97 fps/24.00 fps/23.98 fps, IPB: 120 Mbps, 860 MB/min.
Full HD 1920 x 1080: 59.94 fps^, ALL-I: 180 Mbps, 1298 MB/min.
Full HD 1920 x 1080: 59.94 fps^, IPB: 60 Mbps, 431 MB/min.
Full HD 1920 x 1080: 29.97 fps/24.00 fps/23.98 fps/HDR Video,
ALL-I: 90 Mbps, 654 MB/min.
IPB: 30 Mbps, 216 MB/min.
Full HD 1920 x 1080: 29.97 fps, IPB Light: 12 Mbps, 87 MB/min.
HD 1280 x 720: 119.9 fps, ALL-I: 160 Mbps, 1144 MB/min.
HD 1280 x 720: 59.94 fps, ALL-I: 80 Mbps, 583 MB/min.
HD 1280 x 720: 59.94 fps, IPB: 26 Mbps, 187 MB/min.
HD 1280 x 720: 29.97 fps/HDR Video, IPB: 13 Mbps, 94 MB/min.
Canon Log Dynamic Range
Approx. 800%
Canon Log Recording
4K/Full HD/HD YCbCr 4:2:0 BT.709 8-bit (Internal Memory)
4K/Full HD/HD YCbCr 4:2:2 BT.709 8-bit (HDMI Output)
4K YCbCr 4:2:2 BT.709/BT.2020 10-bit (HDMI Output)
Exposure Control Metering Modes
Real-time metering
Metering Range
EV -3 to 20 (at 73°F/23°C, ISO 100)
Shooting Modes
Scene Intelligent Auto, Flexible-priority AE, Program AE, Shutter-priority AE, Aperture-priority AE, Manual Exposure, Bulb Exposure, Custom Shooting Modes: C1, C2, C3
ISO Speed
ISO 100 to 40000 (in 1/3-stop or whole-stop increments)
ISO Expansion
L: 50, H1: 51200, H2: 102400
Exposure Compensation
±3-stops in 1/3- or 1/2-stop increments
AE Lock
Auto, Manual
Recording Media
SD/SDHC/SDXC Memory Cards
Shutter Type
Electronically controlled focal-plane shutter
Shutter Speed
1/8000–30 sec., bulb.
Maximum Sync. Speed
X-sync at 1/200 sec.
Viewfinder Type
OLED Electronic Viewfinder
Screen Size
0.5-inch diagonal
Magnification
Approx. 0.76x (with 50mm lens at infinity, -1 m-1))
Resolution
Approx. 3.69 million dots
Information
AF point information, Number of remaining multiple exposures, HDR shooting, Multiple-exposure shooting, Dual Pixel RAW shooting, Multi Shot Noise Reduction, Digital Lens Optimizer, AF method, AF operation, Drive mode, Metering mode, Anti-flicker shooting, Shooting mode, Scene icons, AE lock, Flash-ready, Flash off, FE lock, High-speed sync, Shutter speed, Multi-function lock warning, Aperture, Lens information, Exposure level indicator, Exposure compensation, Highlight tone priority, ISO speed, Possible shots, Number of self-timer shooting, Maximum burst, Battery level, Exposure simulation, AEB, FEB, Still photo cropping, Aspect ratio, Auto Lighting Optimizer, Picture Style, White balance, White balance correction, Image Quality, Bluetooth® function, Wi-Fi® function, Histogram, Electronic level
LCD Monitor Type
TFT Color Clear View II LCD Touchscreen
Screen Size
3.15-inch diagonal
Resolution
Approx. 2.10 million dots
Coverage
Approx. 100% vertically/horizontally
Wi-Fi ® Connectivity
IEEE 802.11b/g/n Compatible
Bluetooth® Connectivity
Bluetooth® Version 4.1 compliant
Exterior Dimension (W x H x D)
Approx. 5.35 x 3.87 x 3.32 in. / 135.8 x 98.3 x 84.4mm • Based on CIPA standards
Approx. 5.35 x 3.87 x 2.67 in. / 135.8 x 98.3 x 67.7mm (from grip to monitor)
Weight (CIPA)
Approx. 1.46 lbs. / 660g
* Available AF points may decrease when shooting with AF cropping or in movie mode, or depending on camera settings or lens attached.
** [AF frame size] can be set to [Small].
*** Indicate an inexact proportion.
^ Full HD 59.94 fps not available during EF-S cropped shooting.
RF 28–70mm F2 L USM
RF 28–70mm
F2 L USM
RF 50mm F1.2 L USM
RF 50mm
F1.2 L USM
RF 24–105mm F4 L IS US
RF 24–105mm
F4 L IS USM
RF 35mm F1.8 Macro IS STM
RF 35mm F1.8
Macro IS STM
RF 28–70mm
F2 L USM
RF 50mm
F1.2 L USM
RF 24–105mm
F4 L IS USM
RF 35mm F1.8
Macro IS STM
Lens Type
Canon RF Lens
Canon RF Lens
Canon RF Lens
Canon RF Lens
Focal Length & Maximum Aperture
28-70mm, f/2
50mm, f/1.2
24-105mm, f/4
35mm, f/1.8
Lens Construction
19 elements in 13 groups
15 elements in 9 groups
18 elements in 14 groups
11 elements in 9 groups
Diagonal Angle of View
75°00' - 34°00'
46°00'
84°00' - 23°20'
63°00'
Focusing Actuator
Ring USM
Ring USM
NANO USM
Gear-type STM
Minimum Focusing Distance
1.28 ft. / 0.39m
1.31 ft. /0.4m
1.48 ft. / 0.45m
0.56 ft. / 0.17m
Image Stabilization
N/A
N/A
Provided (Up to 5 stops with compatible camera)
Aperture Blades
9 blades
10 blades
9 blades
9 blades
Filter Size
95mm
77mm
77mm
52mm
Maximum Diameter & Length
Ø4.09 x 5.50 in. / Ø103.8 x 139.8mm
Ø3.54 x 4.25 in. / Ø89.8 x 108.0mm
Ø3.29 x 4.22 in. / Ø83.5 x 107.3mm,
Ø2.93 x 2.47 in. / Ø74.4 x 62.8mm
Weight
Approx. 3.15 lbs. / 1430g
Approx. 2.09 lbs. / 950g
Approx. 1.54 lbs. / 700g
Approx. 0.68 lbs. / 305g
